Leaking sunroof
Hi Guys
I have an 89 polo Breadvan
does anyone know the part number for the sunroof seal? and can i still get it?
thanks
Hi Guys
thanks
is the rubber perished or just leaking i took mine out and cleaned it up then used clear silicone to fit it back not leaked so far
and still opens fine
If it's the factory slider, it shouldn't leak due to the drainage channels running down inside the pillars of the car. These can block up.
If it's a pop-up glass item it may not be a recognised VW one.
Hi there.
its the original factory fitted pop up item.
leaks front right corner. have had glass off and cleaned but it just seems the rubber has shrunk over the years and the glass doesn't sit tight on it.
(1) 867877209A gasket / PROFILRAHMEN
(1A) 867877213 gasket
(2) 867877227A gasket 2318MM /
