Wheel Bolt Advice
Hi all,
Please can anyone offer me advice here.
I have a polo 9n3 and I have 20mm hub centric pcd adapters. I am looking to fit my porsche cookie cutters but have no idea which wheel bolts I need to buy? Size etc?
  • Views 1.3k
do u men bolts for wheel to spacer? or spacer to hub?
Yeah, are you after bolts to hold the spacer to the hub or the wheel to the spacer ?
Sorry guys I mean bolts to fit the wheel to spacer. Knew I'd miss out a salient piece of info!
I think you can use the vw wheel bolts but not 100% sure. just something i heard.
If they are FK adapters they are M14 x 1.5 I'm 99.9% sure so the standard vw ones are the same size thread and should fit, As for the wheels just make sure they have bolt holes bigger than 14mm diameter and you should be fine!
