What other poly bushes fit TCA mk2
God knows lmao. Orange though. Toby!
  • Replies 60
  • Views 6.7k
Well prided inner and outer bushes from Powerflex?? £65 let's hope they fit ok for that price?? Il stick pics up in new year when I get chance to fit them:-) maybe it will drive a bit straighter then
Thing is the stock suspension/ARB/steering setup doesnt help either. especially when lowered by a fair bit.
the lack of camber adjustment is a bitch too.
poly inners seem all wrong to me ...note how the arm isnt just hanging there , they're twisted a bit , poly isnt really ideal for that job imo
the polish ebay outers made a nice improvement on mine
Why didn't you buy the ones in Jordan's ebay link, they're only £20 a pair delivered, the outers must be cheaper too..?
i think these are right -> http://www.ebay.co.uk/itm/280495836579?ssP...984.m1423.l2649
i seem to remember i got the link off here at some point
And The Powerflex outers are good but i criticized the inners because they're intolerant to castor correction, and that's an essential mod to liven up the steering and correct the steering/suspension geometry in the event of lowering the ride height.
Poly bushes make ride so shite
Agree with you there mate, I only used them on my RWD escorts when I was rallying! But this polo front end moves all over the place under power or braking, and both arms and track rod ends are nearly new, and the coilovers seem real good quality! So first job is try remove some play?
As for the polish link the outers are about £25 a pair? So only an extra tenner, and they do look good quality and I'd rather buy from uk as the Polish seem to be taking over where I'm from so goes against the grain a bit!!
It's already on castor blocks, I'm going to raise it a bit anyway and refit the front helper springs, as they been taken off!
Once iv bushed the arms il look into the inner arm mounts, and do a bit of cut and welding to get rid of any twisting coz that's what's ruined the standard rubber mounts fitted now!
Il track it up my self then as I do 4wheel alignments in work! So I'm sure I can find a way round this??
Oh yeah, I mean everything is a compromise with cars to be honest, it's always a trade off between them to find a happy medium. Saying that I don't think iv ever seen Poly's advertised for improving any ride quality
Taking over is a bit of an understatement :lol: some days it like walking down a street in Warsaw.
quit trying to save pennys here and there get hold of
some polo g40 rosejointed inner stearing arms
polo g40 rosejointed inner wishbones
powerflex (the onley poly i will use) the outer wishbone joint ( the one antiroal bar goes into )
then get hold of a ppp stage3 front subframe
solid alloy rosejointed top strut mounts from G-Ladersite.de if the site is still running
prob cost about the £500 mark but worth evry penny :lol:
The anti roll block mounts pictured above are already fitted to my car and look brand new? Il put the outer bushes in on my first Saturday back in work, then also look at the inner mounting before changing to my polys
I might make an adjustable ARB.
Just seen the two posts before mine!
G40 dabsy that sounds an awesome setup! But way out of my league mate!
Cymro, glad you know where I'm coming from in the above statement:-)
Anyway it be a couple of weeks till I can get this sorted unless they arrive before next wkend? Then il fo it up my parents
yes it is a ausome sety up i have it fitted to my weekend toy but to expenceive to do it agian to my daily
if i were you i would just fit powerflex wishbone inner outer bushes to your polo cost about £50 for them
them
MAKE SHORE YOU CHANGE THE WASHERS EATHER SIDE OF THE BUSH ON THE ANTIROALBAR THO
to some thicker ones
your old ones will be F**kd and if one rips through the wishbone its not worth thinking about
o sorry forgot to say poly bushes are stiffer than rubber ones
also transmit more vibrations from the road engine through them
also transmit more roadnoise through (them not mutch tho)
generally making it not such a smooth comfy ride
Edited by g40dabbsy
Does sound good for track car:-)
them
This is what iv ordered, came to £65
Did you just buy or find thicker washers same diameter??
Remember years ago (20) I built a quick mk1 fiesta with 130bhp, I ground the shoulder of the sleeve back on the roll bar to adjust the castor and used washers to adjust it, forwards/backwards! Sounds real rough but worked and done a few rally's with it and no problems!!
Be building one of these 1.6 hybrids next:-) can't wait
Yeah I thought about shimming the ARB that way too mate.
My geometry is setup pretty equal tbh, 4 minutes caster difference side to side which is fuck all, running maximum spec positive caster to g40 spec, but it's still only 2 degrees lmao.
I did slotted holes in billet ally blocks.
Despite grease nipples the ARB wore the ally eventually and caused knocking, shoulda used metal bushes like a shell bearing, in that time I never adjusted them because there was no point. So when I made nylon ones I made them single position.
Yeah I meant actual ARB man. Then again my geometry is sweet so no point lol.
These moved the ARB forward/back to adjust castor. What do you want to adjust?
Length
I would love to see you get all them g40 items and a stage 3 subframe for £500 especially as the subframe alone is more than £500
And i would just like to add power flex aren't all that especially when I've seen cases of their outer tcas bushes torn in weeks let alone months of use
Edited by StinkyPete
get some pictures of this if you make ajustable A.R.B
my bushes have lasted years but i do make shore they have plenty of grease on them
Edited by g40dabbsy
