Mk2 door cards on a mk3
Alright guys, just wanted to check they fit as I've seen a set that i much prefer to my originals , do i have to change the window rubbers to finish it off better as they're shorter in height aren't they?
Nice one
as far as i'm aware the doors are the same, so the cards will fit. no idea abojut the window rubbers though, long time since I've owned a mk2. at a guess i would imaging the internal window seal would need to be changed as it overlaps onto the top of the mk2f door cards, so there would be a gap when using mk2 door cards.
Ok sweet, that's what I was thinking, probs need the mk2 internal rubber...
Yeah jon is correct, they go on fine , but the over lapping door seal looks abit naff. I just fitted a universal seal
Is the dash alignment diff too ..
The Mark3 dash is narrower than the Mark2 one, so there will be a wee gap between dashboard and door, if that's what you mean?
The interior door handles are a different shape, so you'll need some mk2 ones.
