Cleaning windows
I have marks on my windows from where sunblinds have been stuck and other smears. I cant get rid of them, I have tried normal window cleaner Isopropanol alcohol and car window polish. The marks are still on the windows.
I want to get rid of them as the parts of the window with the marks on seems so steam up a lot quicker than the rest of the windows.
Does anyone have ideas on what i can do to get rid of them?
  • Replies 20
  • Views 1.4k
I have tried heating the window up and using a razor to remove the marks. still hasn't worked.
Does anyone have ideas on what to do?
Are the windows tinted?
How long have the suction cups been on the window?
i had the same issue, bit of white spirit/terps sorted it out quite easily :)
The windows aren't tinted but wanting to get the rears done later in the year.
I have no idea how long the suction sups were on. i bought the car in June and its a 06 plate so they could of been on for 5 and a half years
I shall give that a go and see if it works, hopefully it does.
Passed my test today too so can finally drive it. At this rate it shall be to a window cleaners :D
Gave it a go with glass cleaner again today then that didn't work again so i tried washing up liquid that didn't change it so i tried turps and that didn't work. my arm was tired after that so didn't try the polish again.
Has anyone had good results from machine polishing glass? its a expensive route to go if it wont work :D
If nothing else works - white vinegar!
Lick them.
I like licking windows, it's my favourite.
Joking aside I wanna know too.
:lol:
Methylated Spirits
I'm off to B&Q in the morning for some super fine wire wool as that's meant to work really well. i have already been told to lick them and also to take a claw hammer too them and get new ones fitted. :D
go to B&Q and see if they have a long weight available, if not you could put some tartan paint on it? and hang it on a sky hook to dry? i heard it works on another forum.
i dunno if itl solve your issues, but its worth a shot right?
Edited by erixtar1992
I'd try a left handed scraper, they way they apply pressure to the glass works wonders
I need to get a bag of sparks too thanks for reminding me :)
when using the sparks on the window id suggest getting a spirit level bubble to balance on the top. may help you distribute the pressure evenly. obviously the left handed scraper will work wonders either way though.
Top advice, on the Internet and nearly 9000 posts, no brainer
Dont forget the long stand aswell. ahsnhfdjaskfdfss
Pah. Forum user, what does he know
I used to work at the Thorntons factory making hard boiled sweets. We convinced someone to go and ask the manager for a long weight. He told him to come back later and he would get it for him.
Also I'm right handed so do I still need a left handed scraper? ;)
Yes, keep your right arm to hold yourself steady whilst you lick the glass at the same time as scraping with your left
:badgrin:
This reminds me of when I worked at an airfield and the trainees would get asked to turn off the wind sock. One of them went round flicking switches for about an hour. Then gave up and hid away for the rest of the day. :-p
But on a slightly mor e serious not. And this may be silly. But have you tried cleaning from both sides? As it may be possible that it's on the out side? Maybe
They are mostly clean now it took 3 hours with the wire wool and now they are mostly clean got the outsides to do still and the rear window but the others are a lot better. It did make a mass though little bits of steel wool everywhere :D
