it had to be this time of year :(
driving home from christmas shopping n theres goes my gearbox it has been ok last few months so i get near christmas and I'm near pay day n suprising the gearboX gives way :( just had to be this time of year didnt it.
  • Replies 10
oo its a polo 6n 1.4 16v lol :(
i have a 16v box if you want it.
No leaks, noises or issues until sudden failure?
bad timing man :(
can pick up a box fairly cheap on here :)
Just make sure you know if you need a rod or cable change
then fit it yourself, its relativly straight forward once you get going
Driveshafts 6 bolts each
gear linkages 1 bolt
Clutch cable pops out
3 bolts gearbox to engine
2 bolts gear box to starter motor
3 bolts for rear gearbox mount
2/3 bolts for main gearbox mount
wiggle it off
change the clutch while its accessable
wiggle a new box on
put your bolts back in
drive away smiling :D
can be done in a day at home with a basic socket set, a M8 12point spline bit for the driveshafts and a couple of trolley jacks and axle stands :)
Edited by dadude01
bad timing man :(
4 bolts gearbox to engine
wiggle it off
wiggle a new box on
They're easy - 2 hours tops
I always struggle getting it off. And on is worse! Fight for ages trying to get it up past the back lump of the subframe. Been thinking about loping it off everytime I take the box off.
Isn't bad, if you're on your own just rest the box on a trolley jack and it slots straight on
I must be doing this wrong... ahahahaa.
I find the engine isn't low enough (at a good enough angle), or not far enough forward.
Y U COME OUT BUT NO BACK IN?!
I always struggle getting it off.. Fight for ages trying to get it up.. Been thinking about loping it off..
:shock:
:nod:
When the engine's hanging i find there's plenty of clearance, especially on a 6n. Hooking the drive flange over the flywheel is key, as is getting the clutch plate well centred.
Changed the clutch/flywheel on our MK4 Golf TDi a couple of weeks ago, the diff housing was a right bitch to get past the subframe. Especially back up, because the Golf box is a bit heavier than the 085!
Well the only emgine n box i know well is the vr6 soo I've got my mate to do this one should have it back sooony then i have some lenso bsx to go on with stretch tyres sure is a christmas treat for the car not me lol
