Changing headlining in mk3 coupe
So, while i've been learning to drive, fearne has been stood for rather a long time, and unfortunately my driveway is directly opposite a field, so it gets a bit chilly this time of year, while doing various bits to the car i noticed that there was a hell of a lot of wateron the front screen, the driver's side footwell is always damp, and each time i open the doors, water runs out of a hole in the bottom? Is this litterally just an extreme case of condensation, or something worse?
Also, the headlining is always wet at the front (around the interior light, mirror, and sun visors) now i want to take the lining out and recover with something that looks a bit better than this, so i thought i'd do it now while i'm investigating these patches... How do i get the fecking thing out, all the guides on the interweb are for modern cars where the lining is just clipped into the trim panels, but my car doesn't have any trim panels, all the lining goes into the window seals, what do i do?
Am i going to have to have the windows out,oris there something i'm missing here?
Really need your help guys
Rich
  • Views 888
yep glass out , seals off and its glued onto the metal lip ...warm it up and it will peel off
not as easy to mod as what you see being done on modern cars
It's not hard removing it, the glue should be brittle enough to peel off, it's the waiting time when you refit it for the glue to go off etc. but yeh it's glass out, screen and rear quarters
It's the seal on pass side door window when I had it and it was off the road it did it
All I did was jet was the seals and it stopped
