mk3 polo wiring check (Ignition coil)
Good evening everyone i was wondering if i could grab some help, I have a wiring diagram (Pictured below) and i was wondering if anyone could help me....
Could anyone tell me what color the wires are coming from the ignition coil, From the diagram i believe that the ignition coil is labeled number 36 on the diagram.
Now, The positive on the coil should be 15? Am i right? Meaning that the color should be Black? Is this correct?
Then the negative will be the number 1 ? So the wire color will be Brown? Is this correct?
Here's the diagram
Kind Regards
Kieran
  • Views 7.7k
On the Amplifier (21)
Pin 1 Brown = Ground/Earth
Pin 3 Black = 12v supply
Pin 2 Black/Green? = Signal from ecu
on the coil (36)
15 +12v
1 Switched Ground from the Amp (21)
Those wires on the actual ignition coil (item 36)do NOT connect directly to positive and negative (+&-) They are connected to item 21, which I have always known as an ignition 'amplifier', but which your diagram names as the 'end stage of the ignition transformer'
From memory, the connection to terminal 2 of the amplifier is black with a green tracer.
the connection to terminal 3 of the amplifier is black
the connection to terminal 1 of the amplifier is the earth, which, as you say, should be brown.
Regards.
Edited due to the " not coming out as very legible.
Edited by caretakerplus
