AFH lightened & balanced bottom end
block inc internals:
This made a massive difference to the speed that the revs would go up and down!
standard 16v block cleaned and painted black
honed cylinders and new rings around 2000 miles ago
new big end shells and main crank shells about 3000 miles ago
lightened and balanced rods
lightened and balanced crank
nearly new oil pump
timing belt tensioners only have around 5000 miles in them
i will also include a top quality gates timing belt with only 1000 miles on it!
i never changed the waterpump as it still looks in great condition
lightened and balanced flywheel
i shall not be including the clutch as this will be swapped onto my new engine
£200!!
collection only from leeds LS5 3PG
craig - 07846992735
Edited by dubownerbilco
  • Replies 43
  • Views 2.6k
We're the valve seats recut after the guides were done mate?
yep, because i had massive blisters on my hands after doing them! compression results are spot on so they seal fully :)
I mean cut not lapped lol, cause changing the guides can offset them a bit so they don't sit concentric to the seats
hmm, well he didnt mention it when he fitted the new guides, but if its standard procedure anyway then ime sure it was?!
i shall contact the lad who did it and find out :)
Deposit taken on the cams!
valve seats were re-cut, i phoned my friend today :)
Thought there would be more interest?
I will have a think mate.
Weighing up getting my own head fitted with larger valves and such and a fancy cam kit or just getting some cams alone with a standard/flowed head.
Ok mate, well ime open to offers, that was just a ball park figure to get things rolling!
What does removing the mushroom achieve mate? Just curious
To set the vac advance in one position as bike carbs tend to advance it too much!
would the carbs fit straight onto a 1.3 mk2 engine? also how much deleivered to bournemouth? very interested!
Not really, the flange is different and you would need smaller jets in the carbs, the rest of the setup would work fine but i want to sell it as a whole!
hi, I'm interested in your bike carb setup, how do you think they would run on a 1.6afh?
It would need bigger jets in the carbs but other than that it would be fine mate!
deposit taken on carbs
open to offers on block and head!
421 manifold (unsure of brand)
had EGR valve thing proffesionaly removed so it looks neater, lambda boss has been cut off so it can be sleeve jointed onto rest of the system
£100ono
Don't suppose you have just the de cat pipe i could buy do you?
£100ono
no, it was sleeve jointed onto the rest of my custom system so there was no dedicated decat pipe as it was on a mk2 anway :)
What sort of power were you achieving from this set up?
Officially made 111 on the rollers with similair torque, although not the power expected at all which is why i would rather sell it in parts. The only conclusion we could ever come to is the mods not complementing each other to give maximum power! It was still a very fast car and did the strip in 15.171
Box?
Also will the 4-2-1 go on a AFH/ARC conversion?
Box?
Nah sorry gearbox isnt for sale, its a gt box with a quiaffe diff fitted. :)
If its still the afh head then yeh the 421 wil fit fine
Box?
Maybe take the mani off you.
Cool, Might take it then, I'll let you know, What about the head whats left>?
