Mk2F fronted Mk2 Polo
so most people have asked the question or heard about the mk2f front on a mk2 conversion at some point on here if your into 86c's, so here is one from german ebay that has been done
http://www.ebay.de/itm/VW-POLO-86c-Coupe-M...5#ht_512wt_1397
its not exactly amazing but i thought it was a little interesting to see one thats been done ;)
  • Replies 12
  • Views 1.2k
I would like to do it the other way round and have a mk2 Front grill on a mk2f
Fair play for doing all that work, we all know there's a lot involved...
BUT HE'S GOING THE WRONG WAY...
It needs to be facelifted car which has been unfacelifted.
Mk2f back to Mk2 :)
It also looks as if its been sat there for god knows how long bit of a sorry state
Also mk2 over mk2f front end Anyday
Can't get my head round it, just buy a mk3 or vice versa
I don't no if actully been converted, when I was in Germany I saw a bog standard looking G40 with a mk2 rear and mk2f front, they might of only released them in German, I've got some pictures of the G40 that I saw, will have to dig them out, it wasn't exactly a nice either few patches of rust hear and there! Pictures to follow.....
coool! i like it :) looks like a polo with a jetta front hah
Looks like the front bumper is a mk2 item given its poor fitment with the mk2f front end
Has potential but would need a lot of work to get to any decent standard, the rear quarter looks like its got the consistency of pringles under the paint
if you look at the poor lines which run around above the rear lights you will see they dont line up. i think this is just a mk2 bootlid,lights and under panels fitted to a mk2f.
The front wings are mk2f also - which when you look at the mk2 you will see the A pillars are totally different and he would have had to replace those to make them fit like that. i think I'm right in saying its a mk2f originally hence the title 86C
MK2 and MK2f are both 86c. MK1 is 86. Those look like mk2f wings up near the pillars, but there is definately something not right with front edge. It carries on alot lower than it should. The bottom edge of the wing is usually level with the bottom of the strip below the headlights, and theres a gap between there and the bumper. Those clearly continue behind the bumper and look at the gap between the wings and the light panel. Wings angle inwards slightly, as on a MK2. This definately started as a MK2, Look closely at the door cards, they dont cover the entire door inside, plus its an '88 :-)
Edit: Just translated the text. It says it is a MK2, with a complete MK2F front end fitted, including dashboard and also an NZ engine.
Edited by malaga red
What is it with those rear lights collecting dirty shit in the edge that meets the rear quarter? Mine have done exactly the same
BORING! Try a MK2 with a "Jaguar" front end...
+1! mine are starting to go aswell!! i may chuck them in the oven to seperate them then give them a bloody good wash!
