Leak on passenger side in 6n
Right, I went to get in my car today and noticed a bit of a puddle in the passenger footwell! I've read other posts suggesting it could be the pipe for my rear wiper..however when I drove te car today I could hear water sloshing about from somewhere on the front passenger side?? Does anybody know where this leak could be coming from?? My door sill seems fine, windows were up. Also where are the drainage holes under the scuttle tray? I couldn't see them when I checked under there cheers!
  • Replies 11
  • Views 1.3k
It's worth just shaking the door to see if you can hear water inside. What can happen is the door fills with water to about the level of the door card, then it 'overflows' into the foot well.
Regards.
Regards.
Cheers for the reply mate..I've tried shaking the door and even took the door card to have a look and it's bone dry! Still can't see where it's coming through tho
Take it to a local petrol station jetwash,blast it over with just the shampoo then check inside
the suds from the shampoo are quite visable,should see where its entering the car
Sounds like the drain holes in the scuttle pannel are blocked.check to see if your pollen filter is wet. The drai. Hole is pollen filter side in the courner you should see your indicator wire going through the hole
Ye I got a sunroof but all seems dry mate
If you read that link, the drains for the sunroof run down the "A" pillar and then out to the outside, so it could be the drain pipe has come off the joint where it exits to the outside.
I'll give cleaning them out a go and see if that helps..how would I access the pipe if it has broken to replace it? Cheers
Thats an issue both me and mates have had. Once the shit was moved both wings were letting water drain. Always shitty old leafs.
I had it happen to me to. Had about 2 inches of water in both footwels :(
one side filled up by water getting in the pollen filter and drivers side filled up by water coming through where the bonnet cable goes into the engine bay :( bad times. I check my scuttle regually now
Edited by djj92
Same as the above few, take your scuttle panel off and they'll be a nice pool their, push/pull the shit out the drain holes and bobs your uncle!!
Advise against doing it on your drive if its one on them nice ones that you've just spent ££££ getting done
