mk2 golf type 19
Putting my mk2 up for sale/p.x as I want something a little bit newer.
Basic details
Jade Green
3 door
1.6 driver on Weber carb (read below)
96k miles
MOT until September 2013
Tax until end of February 2013
Mods
JOM coilovers, probably done around 5k miles, helpers out, and bumpstops out on the front, and spring caps shaved down (still have helpers and bumpstops)
mk3 top mounts (allows the shaved spring caps to sit properly)
Chassis notch on the drivers side
Tie rod notch on both drivers and passenger side (all notches done professionally. Sealed, welded and undersealed
Arches flattened all round
Compomotive TH Mono's 15x8 et25 all round, all mint apart from slight curbing on one of the wheels on the top of the rim (not very deep or noticeable)
165/50 nankangs all round, covered around 1000 miles
5mm cheap universal spacers on the rear
Interior
GTI front seats from a 3door in very good condition (drivers side doesnt lean forward)
Early style centre console
Early style 2 spoke steering wheel
Boot turret carpets
Rear currently stripped out (although I still have rear seats (non GTI), seat belts, parcel shelf etc that I can re-fit)
Bad points
Main problem is the engine. I think the carb needs setting up properly as the car is currently getting very poor MPG. It's averaging around 18-25mpg around town, and 30-35 on a run
The engine is also burning oil and when the car gets warm you can smell it whilst driving
In the cold weather the choke needs to be out until the car warms up other wise the car struggles when you accelerate (thing this is normal)
I believe the driveshaft is going as there is a knocking noise when accelerating, its been doing it for a few weeks but doesn't feel like its going to give way, but replacing it would probably be a good idea
Theres a fair bit of rust on the car, mainly front of the rear arches, a hole on the bottom of the passenger wing (isn't too much of a problem as it just goes up behind the wing), few bits on the door. Although the underneath has had holes all welded up so its all solid
There is 2 small holes at the bottom of the windscreen which cause the footwelds on both sides get a bit damp, obviously in the summer when we don't get much rain :unsure: its not too much of a problem
There's a relatively large dent and scrape on the passenger door
Passenger side window doesn't work
There may be more that I'm forgetting and I'll put down if I remember them....
I realise there's quite a long list of problems but if you know what you're doing it really won't take a lot to fix them.
The car will be cleaned inside and out soon...
Now, I'm looking for £900, or £550 without the wheels (would rather sell with wheels)
May possibly be interested in P/X but really fancy an 316 e46 BMW, so if you have one we could make a deal.
Located in Basingstoke, Hampshire
PM me or text me on 0seven588 one4219five
Pictures...
Drivers side rear arch;
Passenger side rear arch;
Hole in the wing and rust on the door;
Dent/scrape on the passenger door;
Interior;
Edited by AndyBMX
  • Views 566
Swap centre consoles? I got a normal one
I'll give cash your way also
this still available?
