polo 9n3 mirror indicators
Just wondering if you know where to buy the side indicators on the mirrors on the polo 9n3 as mine have cracked
  • Views 2.5k
i would also like to know this as i may of reversed into my neighbours drain pipe when getting onto the drive...only reversed into it twice :D
Or a part number i have elsawin on my laptop but i don't have my laptop to get part numbers :(
Passenger
Driver
Same seller, it's interesting how the driver's side costs slightly more than the passenger, more mirror-to-mirror collisions with other cars compared to mirror-to-wall? ;)
Edited by Ben90 FSI
Passenger
Driver
They don't look like the ones on my 9n3. :S
They look like the right ones, but the pics are from underneath.
Best off asking the seller first. Just to make sure as it may well be a gallery image.
Also, the price isn't that far off a complete mirror on eBay, so best to search around before hand.color doesn't matter as the painted section just clips on and can be swapped easily.
Hth
Yeah it's from the underside, if you have a look at your mirror from underneath you'll see that it's the black bottom section.
As for changing the whole mirror, why spend twice as much on a non-OEM part when the genuine unit you have is just fine? plus it's a ballache to change in comparison. :?
I should have mentioned before, I bought one of those indicators from the same seller and replaced the cracked one on my 9n3 with ease. Pop off the top cover, remove the mirror glass for ease of access, undo 2 bolts, unplug the yellow wire and replace the indicator. £20 and 20 minutes job done. :)
Edited by Ben90 FSI
