painting interior panels
I want to paint some of the interior bits in my 6n2 gti gloss black as they are pretty worn.
does anyone know of a guide showing what to use? i dont want it to look cheap and tacky and want it to last.
cheers.
  • Views 1k
cheers.
interior bits you mean what dash. doorcards ? interior ? handles ?
well ill take a gess that you want to spray some rorm of plastic
get it done by a professional body shop or it wount last 2 mints before it chips or peals off
if you spray example interior doorhandle it will chip off easy and will also crack as plastic can bend flex
personally not a good idea but evryone to there own taste
cheers.
i done my door handles using ordinary satin and gloss spray cans from halfords and they turned out fine an they've been on a good 18months now
as anyone will tell you it's all about the preparation
As above, it's all in the prep, but if your not that confident in painting, then either ( as above ) get it done by a professional, or try vinyl wrapping them. You can get all sorts of colours and finishes. I did a friends in black carbon, that's door handles, centre console, lower cubby, heater panel, air vents etc, looked pretty good too, and best of all it can be removed at any time.
Hth
