1.3 8v tunning head work
Is there any head mods u can do sept from porting and polishing
Can u get a race type piston for them or race crank
  • Replies 14
  • Views 908
  • thats not head work then. and what engine is it? how much you looking to spend? what do you wont out of it? nead to tell us more...
You'll spend a small fortune maybe getting 150hp
1.3 avv 54.000 miles plans are bike carbs and gt cam just more grunt
might be better just saving up and getting a gt engine..
What do you want from a race crank and pistons?
Wht would be the point of saving for a gt engine the only thing diffrent is the fuel management
And camshaft please correct me if iam wrong
and ignition, and higher compression ratio.
i wouldnt either tho. id get an ABD bottom end.
I'd just get an AFH or an AEE
so get your facts right. better putting a gt or g40 in than pissing cash away on a "race crank" and pistons
whoa chill out man?? lol
You could get a 1W crank and pistons and go for mad high compression ratio. But one of those is several hundreds alone, then pistons on top etc.
It really does depend on what you want/want to do. If it's a project, then there's lots of parts you can mix and match to get various performance gains. If you can find the parts, there are also VW motorsport items you can use. If you just want more power, then an engine swap is the only economical choice. Also, these are well covered and have been done by plenty of people on here. Building a 'tuned' 1.3 is a less well trodden path and you'll likely be doing plenty of your own R&D.
Consider insurance too, as even for me driving for 10 years with 4 years NCB, I'm forking out £450 for third party and 3000 mile limited. Thats on a classic with AEA (1.6) and other mods.
o right couldnt really find much in faq on the best engine build using 1.3 so not really point less or the carb inlet
best engine build on a 1.3 is just get hold of g40 engine and running gear
your be able to get 150bhp out of that engine
