Name that part - from a '92 CL
Pint to whoever can tell me what this is and where it goes!
D28E5E5B-6F2C-4E1D-B0B1-5688D45C6B2D-397
8CA44455-2CC4-4673-86BF-FDAEB47BFD3E-397
It's probably an interior part, and likely to be part of the dashboard; heater blower unit or steering column assembly.
Found it in a bag of bits from the bodyshop, and I've no idea where it goes! Sadly there's no part number on it so I can't look it up on ETOS/ETKA etc - so I assume it's part of a larger assembly.
  • Replies 22
  • Views 1.7k
how big is it? Annoyingly it looks really familiar! :roll:
you sure its from your car?? :)
Its the heat shield for a flux capacitor.
Job done.
its a shim from the steering column Andy
It's about 2 inches long.
Can't be 100% sure! But the other bits in there were.
did you remove the inner part of the upper steering column from the outer part at all?
Think the bodyshop did, yes. Reckon it's part of that assembly?
hmm i've just fully stripped and rebuilt the column on mine yesterday and it doesn't look particularly familiar.
I know the mk2/3 golf has them cause I remember pissing about with them while rebuilding a mates steering column while doing a vr6 conversion. I'm sure I had one fall out when I had to fit the mk2f column into my mk2 for the later dash to fit as well, but its been a while so I may be mistaken
Iirc this sits in a grove in the inner shaft of the steering column and then the whole lot slides into the outer casing with the ignition ect on it. Just spent ages on Google trying to find a picture to show how it sits but can't find any evidence of it existing at all, not even on the golfs I know its on :?
Can't see it on ETKA for the steering column..
definitely wasn't on mine, i literally stripped all of that to remove the ignition barrel yesterday
Could it be number 8 on here (mk2 golf steering column, called a spacer plate)
On the polo does the inner shaft (8) not split in two halfway down?
I'm thinking that that might be what it does on the golf and that's where this part is. I know on my mates golf we had to mate part of the mk2 steering shaft with the mk3 one to work in his car, and this part came into play some how then. I remember this because his mk2 shaft was rusty as hell having been left outside for a good 6 months, and this part had to go on it. Just wish my memory was better than it is, but it defo goes on that inner shaft some how
Thinking about it I think it acts as a kind of clip, its put on one part of the shaft and slid into the other and that part clips it into place, then to pull it apart again you have to push something through a hole to push that part down to release it
Edited by Mclovin
Cheers Guy - DK said something similar on Club G40 too, so I'll pull the column out later on and have a look.
My column does split lower down, which isn't shown on ETKA for some reason (possibly because the pic shows LHD and the RHD column is different?). Not surprised the part isn't in ETKA, there's no part number on it - so I assumed it was part of a larger assembly.
Haven't got ETKA to hand to check, but I think if you look up an earlier Mk2, it shows the 2 peice steering column, so that might put you in the right direction.
Got to be some sort of shim though, give the column a wobble and you'll probably be able to feel where it isn't.
Guy wins the beer!
Was obvious once I pulled the column apart...
Fits here:
692DF58A-F217-4496-A8B6-AD643C58D7C4-723
Showing it in position:
54E94713-24A6-46AB-AAF6-31A8685749F5-723
And another shot showing it sticking out the end of the upper section of the column (right-hand end of the column in the pic):
115C31D8-5B8C-45BB-BC34-C1CD143D177B-723
Shiver me timbers :lol:
Knew it was something like that but just couldn't get the image in my head of how it went
Andy does your car have the later spec column on it with a UJ on the end?
i was beginning to worry mine should have one and didn't, but it could be because mine is an earlier column?
This did my head in, I thought I knew every part of my car..
There was no need to pull the telescopic column apart though. Thanks to having the crap fork type in the '85 i swapped a later telescopic steering column into mine without that spring falling out, but then i didn't open the column.
Easy for the lower section of the column to get stuck where it bolts to the steering rack pinion though, as it needs prizing apart with a lever first, else it won't let go of the pinion, so that's probably why the column slid open and came apart.
Mikey - the bodyshop pikeyed it apart, not me - hence the confusion. Have only ever removed a column whole.
Pinches - it's an earlier column.
Yeah i figured that and i meant them, i just didn't wanna sound like i was calling the bodyshop retards though whilst they're not here to argue the toss :lol:
Pinches, I quite fancy the late UJ version, should enable the steering wheel to be safely lowered an inch or so.
yeah i was thinking of putting the later column in mine for the same reason, particularly now the seat is lower in mine and it has a floor mounted pedal box in
