Leon Cupra R Splitter
Hey guys and gals. What the best way to fit the Cupra R splitter to then original splitter on the 9N3 ??
Any ideas.
  • Views 1.2k
Are you wanting to mount it under the original splitter? I would imagine a load of self tapping screws and washers?
If you wanted to replace it then unclip it and see if the seat one lines up, if not then you will need to trim the tabs, and you may well need to still use a few screws to hold it in place. I wouldn't use glue, as you may want to remove it later on.
Want to mount it under the original one. Ok. Take it you have done it already ??
Like mine?
419A1974-E3CD-4535-AA39-0435C9C3E9B4-829
put it on, screwed it in place and then cut off the edges.
