will this 6n2 door fit?
will a front passenger door from a 5door 6n2 fit my 3 door 6n2 cheers dale
  • Views 1k
No.
No.
abit blunt but straight to the point haha I can only find one in my color in a 5door grrrr how much roughly is it for one door spraying fully cheers
If it's metalic it will need to be blended with the rear quarter and wing, so the whole side plus the door shut. Ball park it I'd say at least 150 for a rough job.
Although what I have done many times is get a premixed can of paint from either a proper paint shop or halfords etc, then scotch the whole door , so all the parts that show when the door card is fitted, and then give this a good few coats of paint and around all the edges so you get a bit of over spray on the outside, then lacquer. Then fit the door, and get the outside done at a body shop, as this way you've done most of the donkey work so the labour is a lot lower.
Also, if you do find a door in the same color, it is very likely to have scratches and probably spots of corrosion, and not to mention that most colors will have at least three shades, so the color is never going to match 100% and will show up under sunlight.
What's wrong with your surrent door?
Hth
