Mk2 Doorcards
Sorted please delete
Edited by Hammerheed
  • Replies 17
  • Views 1.5k
I have the two rear ones
Just destroyed my front ones tho :/
Let me know if you want the rears
No!!!! gutted to hear that, I've got rear ones that are ok, its the fronts thats really need replacing.
thanks for the heads up thou dude.
Anyone else got these?
Bump, anyone?
Got a driver's one - you're 3/4 of the way there :)
And I may have a damaged (tear to the board, could be repaired) passenger. I know I have an odd one, need to check which side
Cheers guys,
lf you could let me know that would be great.
anyone else got some fronts of these? would love some minters! :-)
Bump for the weekend
February bump
Found it!
Will be in touch in a bit.
I'm after exactly the same if anyone's got any spare??
I've got a mint set which will be using in my mk2 when it's ready for an interior.
I've also got a second set which the rears are mint but the fronts are fairly badly damaged. They have oval speaker holes cut in them were the door pockets go, the vinyl is ok but the wood is warped and cracked. I'd be happy to send you some pictures by pm if you are interested. Please pm me to let me know,
PM'd you some piccies.
March BUMP,
I've got a drivers side lined up with Yeti, anyone got a good passenger side? I'll buy a full set if needs be..........
not interested in mine?
Cheers for the offer runforrest,
but unless your interested in parting with you mint fronts, then I'm sadly not.
I really need them in better condition than the ones I have already.
i have a full set! in good condition.
things to note are that the front ones are a bit ripped around the door latch pull lever doodad. its all hidden apart from on the left one underneath it comes past the plastic trim by a very minro amount but if you look for it you can see it. i think if you coloured in the orange bit it is stuck to with a black pen it would be almost undetectable. can get pictures if you are interested? what is the going rate for a set of these?
edit: when i say ripped around the door surround it isn't a rip going away from the hole but more like bits missing because someone in it's past had snapped the surrounds for the latch pull and glued them on. anyway. its all invisible with the surrounds except you can see a slither of orange on the passenger side under the surround if you look fo it.
Edited by lobbster
Now got about two and a half good ones. The Driver's one's mint, passenger's ok, and you might be able to get away with the nsr
