torque chart for 6n2 gti engine
can anyone help?
need all torque specs for the engine everything from head bolts to the con rods and crank shaft.
many thanks
matt
  • Views 7.6k
I use the MK4 Golf Haynes manual, the 1.6 dohc 16v engine in that is basically the same engine just without the VVT system which doesn't affect what you need.
Try http://UK-MK4s.net or something like that, must be a manual you can download from there or somewhere.
This might help you out pal. ;)
Ah glad you posted that, I was going to do exactly the same in the morn
Do you have these specs for the AFH?
There isn't much difference but here you go :-)
Cheers harris, after all the reading and info i have found on here (including post from yourself) to build my 1.6 AFH, and carry out various other things, helping others out were i can is no problem. Cheers guys, Nick.
perfect what a diamond bloke!
cheers
matt
