Mk2f polo coupe side skirts
Happy new year everyone!!.. Well tomorrow is going to be a sunny day, so I'm going to get to work on my car. I have a few jobs to do but I'll start with the body work..
I have a Mk2f polo coupe (CL). I have some side skirts that need attaching to the body, but the attachments are covered over on this model.
Could someone advise on how to attach the side skirts to a Mk2f (CL) polo coupe please?
-do I need to drill out the coverings to fasten the trim, and are they riveted on (or how are they attached?)? Not sure how to go about this job.
Any advice hugely appreciated.
Cheers!!
If you look along the sill you will see small disks in the paint. use a small screw, 4mm rivet or 4mm drill piece, then push gently against the middle of the disk and the hole maker should go through easily.
The disc you see are a piece of thick paper and there not always central to the hole their covering.
To attach mine I used 5mm rivets with a washer (the stock holes are designed for 4mm rivets any bigger they will need drilling to suit).
Edit: if the cars been re-sprayed then the disks might not be there or visible best way to try and find them is put the trim on position and probe with a long 2mm drill bit.
Thanks mate, all sorted!. :thumbsup: :-D
Edited by Nick_593
