Semi-smooth 6n2 front bumper?
Having finally got around to getting somebody to get a rolling shot of the polo...and doing the editing myself, I have decided it looks ALOT better with no plate - but don't want to fully smooth the bumper strip off, just continue it where the place recess bit is
So how to people usually do this? Can you get a section of bumper strip, cut the existing section out and replace, fill and smooth it in?
Thoughts and comments welcome
oh and here's the pic that got my onto the subject:
http://www.flickr.com/photos/lsr-photograp...in/photostream/
  • Replies 8
  • Views 3.1k
Just fill + smooth the number plate recess then spray it up
Fair doos matt cheers....best to build up with fibreglass then filler to smooth?
Yeah man :thumbsup:
Erm...no.
If it was me, the recess would be cut out and fresh piece of flat plastic plastic welded in.
If you just fill it, imagine how annoyed you'd be if you twist it and it pops out.
I've seen it happen.
Yeah man :thumbsup:
PAHAHA, As Rob sais mate, do it propelry or not atall as it will look much worse when it falls out if not done right.
Sorry guys I think you misunderstand - I don't want to remove the bump-strip itself, there's just a slip "dip" around the top of the number plate...i would look to relocate the plate so would just need to continue the bump strip (where it recesses)
I understand that if I were to remove the strip then i would need to plastic-weld something in first, not just fill it all in :)
Edited by lsr-photographic
That's both of your opinions... I am not wrong either its just a cheaper way of doing it so quit yo bitching
Quite my bitching? No.
Yes it's the cheaper way, but it's also the shitter way.
May aswell do a job properly first time rather than doing it the lazy way and having up redo it when it eventually gives up.
