mk1-2-3 Coilovers full set 120mm+
Hey i am selling my mk1 golf coilover conversion for mk1-2-3 polos
they are mk1 golf coilovers converted to fit the early polos
I made them and ran them for about a year but they are in perfect condition no rust or seizing as i kept all the threads greased up with special spray
included is:
a set of golf coilovers with solid lasercut arms welded on profesionally in a lower position for going stupidly low
a set of mk1 golf hubs with the correct size ball joint and the steering arms cut off for neatness and tidy looking
a basically brand new set of wheel bearings 300 odd miles if that
a set of basically new genuine audi 80 top mounts the correct fitting to go straight into the polo so no messing about swapping bearings from mk1 golf top mounts to polo ones
2x mk1 golf outer c.v. joints that go straight onto polo driveshafts these are still fitted to drive shafts atm which you can have also if wanted
2x rear golf coilovers
the fronts also have polyurethane bumpstops fitted
these will go stupidly low i was still running them with the helper springs fitted and 15-20mm of thread left at the front
they also have adjustable camber built into the hubs/coilover mountings so enables you to run some front camber
I'm looking for £420 collected for these as they are all built up and practically ready to bolt straight on to your car
i could also help you fit them at my house for a smalou need these basically
120mm+
Thanks for looking PM or Text on zero7733282522
Pictures
  • Views 327
Popular Days
provisionally sold
Deposit taken
Edited by StinkyPete
