Will this steering wheel fit a 9N Polo?
Here it is:
http://www.ebay.co.uk/itm/Audi-A4-Quattro-...=item4abfecd8e0
Might be a daft/noob question, but will this fit a 9N?
Was also wondering about MK6 Golf/6R Polo steering wheels with the multifunction, I'm guessing that wouldn't work or would take a load of work to wire in?
  • Views 4.9k
Pretty sure that will fit. Might have a gap between the trim thought.
I had a scirocco wheel in my 9n3, so a mk6 golf and 6r polo will also fit.
Mine had the MFA controls and DSG shifter buttons. Thought of wiring it the the setereo, but you would need the clock spring with the extra wires for them and then make up a loom to the setero. Then you may have to get an adaptor to translate it into a language your headunit understands. I also thought of using the shifter buttons for the missles and front mounted machine guns... But decided against it.
Edited by dixy
