X reg Mk1 Golf Cab
1.5 petrol carb, 4 speed
Red interior, It has got wet and covered in cat hairs. It could be saved as its pretty cool.
Pretty much all the panels are shot with massive holes or lots of rust. I'm going to try and remove the wings as they will be good for repairs and the tailgate is solid iirc.
The roof is good bar a very small hole over the drivers door.
Email - Winston16v@hotmail.com
Location - Manchester
Phone No - zero, Triple seven, twenty five, nine hundred, Thirteen
  • Replies 12
  • Views 753
i'm after a rubber hose off the water pump,
its a short one that's fatter one end than the other,
i think its about 6" long, typically i can't find one new
and it's all that's keeping it off the road.
I can sort that out for you :)
What else does it go to from the water pump?
some metal pipe at the other end, tbh i can't remember
and the car is at the workshop and not local either.
Dude the accumulator on the engine, my housemates in need of a working one for his cab, gimme a holla boy.
Should have tyres for you by the weekend if your still in need :)
Is it a plastic or a metal one? I have got the metal Golf GTi one at home. The plastic Golf cabby GTi one is in a bag of pumps I gave to Arun. Let me know which one you need either are on the house. :)
Sorry man. I'm not sure on the tyres now after looking at picture... bit to extreme on an 8J :lol:
Clocks? Looking for MFA ones
Sorry dude. No clocks and its to early for MFA
hey dood i could probably do with the lower windscreen section as mines rotted out above the heater matrix, lemme know your getting choppy choppy as i can come over and cut it out myself if you want :)
also sorry about not getting back to about the accumulator, we ripped one of rich's engine in the end
Edited by grungeisdead
Yo!! Not to worry about the accumulator.
The screen surround is 100% rot free. I know Arun wanted some of it so I will find out which bit. Fingers crossed it can sort you both out :-)
you still got this need wings and rear arches to weld to a different car?
