Faulty o2 sensor?
Hi guys, after changing the EGR valve the other month the dreaded engine management light has come back on, the cur runs ok, seems sluggish when accelerating. I have invested in the VCDS kit and the error codes are as follows:
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 D
Component: MARELLI 4LV 3979
Coding: 00031
Shop #: WSC 00000
VCID: 132575C061627D808CE
4 Faults Found:
17582 - Fuel Trim; Bank 1
P1174 - 35-00 - Injection Timing Deviation (Balance Fault)
16710 - Knock Sensor 1 (G61)
P0326 - 35-00 - Implausible Signal
17598 - Linear O2 Sensor; Reference Voltage
P1190 - 35-10 - Implausible - Intermittent
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1
P1196 - 35-10 - Electrical Malfunction - Intermittent
Readiness: 1010 0001
Address 03: ABS Brakes Labels: 6X0-907-379.lbl
Part No: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Coding: 05603
Shop #: WSC 00788
VCID: 4385858051822D007CE
2 Faults Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
35-10 - - - Intermittent
To me it looks like an o2 sensor fault (and an ABS fault which can wait!), but i think the car (vw polo 6n2 2001 1.4 16v) has two o2 sensors.
What checks/diags can i do to narrow down the cause of the fault, i don't want to randomly start changing parts and hoping for the best.
Also the car has a very loud tapping sound, have read elsewhere on this forum that it could be the hydraulic tappets, what problems can this cause if left unfixed?
Thanks for any suggestions.
  • Views 7k
So, the ABS fault is a quick fix. The fuses on the top of the battery corrode and the pump gets "low voltage" and flags the first code. That, and the dead sensor on the rear left.
The knock will probably clear, it'll just be shite fuel at one point.
Lambda sounds goosed though, the reference and the sensor itself. Bank 1, Sensor 1.
It's the one at the exhaust manifold (the first one). I fixed mine by sticking it on a blowtorch. Worked for a week then packed in. Got a second hand one, fuck paying the cost of a new one. hahaa.
Cheers Adam, will take a look at the fuses etc, as for the Lambda have looked at etka and get the part number: 030 906 262 K
But looking online i can find the part but with a different letter on the end J or G but not K, does this matter?
Here is the one i was looking at: http://www.ebay.co.uk/itm/GENUINE-BOSCH-La...=item257872da0e
It doest specify if its for before or after the cat...
Edited by bart
