SUBWOOFER HELP!
where can i feed the power cable?
i keep seeing people say under the glovebox but i cant see anywhere?
please someone help, the lack of bass is DEPRESSING! :-(
  • Replies 8
  • Views 1.6k
Are u trying to run it from under the bonnet t inside if so the is a grommet on the drivers side of the bay just under they wiper that goes down to the fuse box inside the car that's where I ran mine
Is this a 6n2? If so i ran mine though the gromit just down behind the battery though the passenger side and then you have to rip up the carpet under the glove box and the wire will be behind a little piece of plastic i just cut the plastic and felt around inside for a bit. It is a bit fiddley but having a friend help makes it 10 times easier.
Will have a look tomorrow to dark now, thanks for the help:)
Hi sorry i forgot to mention its a 9n but thanks for the info ;)
if it helps anyone i managed to get the power cable through
under the glovebox there is a pipe for the rear washer
just pull that out as its held with a rubber cover,
once you do that there will be enough room for the power wire to get through,
will post a pic tomorrow to help anyone who needs it :)
just wondering now though where would i put the earth wire?
iv tried everywhere to no avail
any adivce is welcome
cheers
Edited by KtheCreatorMan
earth wire for amp can be bolted to any metal as long as you sand the paint off so theres a good current. have you tried the rear seat mounts?
Or Rear wiper/light earth, make sure its done up tight though, your lights might go batshit if not :lol:
On my 6n2 I drilled a hole behind the pollen filter and used a rubber grommet and some mastic to seal. This fed it behind the glove box and this is where I located my fuse - so it can be accessed by removing glove box. You could feed it into the glove box and mount the fuse at the back for easy access if you prefer. Then ran behind the carpet and trim panels along with the cars existing cables.
I found a ground mounting point with a free point behind the first aid panel on the right hand side of the boot which was convenient.
Not sure if this goes for the 9n though, sorry!
By the way, run your audio cable on the opposite side of the car to avoid hum/interference from the mains.
Edited by skamuk1
