Water in the drivers side front floor y 6n2
Nice bit of weather today so decided to clean the interior started to hoover out the front passenger side floor and there a pool of water lying there and also the rear passenger side is wet as well...??Anyone know where it might be coming from.
Thanks for any replies.
  • Views 1.2k
If you open the passenger doors and one at a time shake them can you hear any water splashing around?
Also may be worth checking the drain hole under the scuttle panel passenger side (although wouldn't have thought that would get it to the back but worth a check anyway)
And a stupid one but it must be asked, the windows all the way up (sometimes in the rear if the handle is fitted facing rear of car when window is up all the constant bumps can knock them down a fraction)
Edit: can't remember which way they wind up on rear so may face other way
Edited by matt01
That, and there's a grommet under the carpet that sometimes pulls, Atleast, mine has, and the carpet got soaked because there's now a large 30mm hole in the floor.
[/quote
Thanks Matt i'll take a look tomorrow.
Cheers Adam i'll also look at this in the morning.
