Mystery Plastic Bung?
?Can anyone identify this plastic bung/clip thing which i found when i removed the pollen filter housing to try and sort my water leak,it was just lying there underneath it not doing anything in particular???
  • Views 1.4k
I'm guessing it clips in the underside of the bonnet pal.
Cheers,i'll have a look in a bit.
Done some more digging regarding this part and trying to find out if its related to my "water in the front passenger footwell dilema" which is still not sorted.
I cleaned up the back of the part to reveal the number on it,and i typed the number into google and ....
it cam up as this..... CLOSE OUT PLUG. Volkswagen (VW) # 1C0955440..
Question is ?what the heck does it do,and where is it from.
It should be covering an access hole in the bodywork, either in the boot/backseats over the axle or somewhere under the carpets in the cockpit.
Is your scuttle tray filled with water? Some times the drainage holes get blocked with leaves and crud. A coat hanger and hot water help ease and clear the blockage. There is a drainage channel that leads to the wheel arch.
PoloD.
PoloD.
Yes mate the scuttle drain holes have been cleaned,and the door seals are in good nick,no sun roof .
To me it deffinarly looks like it goes into the washer jet acces holes in the bonnet
I don't think there are any bungs like that in the scuttle area have you checked the cabin filter seal? Best way of checking this area is to remove the Bonnet and scuttle trim, then you can see it all well, and no doubt spot where it's leaking.
Also, do you have a sunroof?
