Bonding metal to plastic
Even though I work in a bodyshop, even I have to ask advice sometimes.
Basically I need some adhesive that will bind metal to plastic.
That'll be strong and won't crack, sink or be visible and must have some degree of flex to it.
I've thought about:
3m panel bond, yes it's strong but it doesn't offer much flexibility and doesn't really like plastics.
Sealer adhesive but don't know how strong it'll be at holding the two together.
What do people recommend?
Any pictures that shows what was bonded together would also help.
  • Replies 16
  • Views 2k
Depends what sort of plastic. Generally speaking though, som sort of 2-part like araldite?
There plastic and metal are both automotive. So plastic bumper and steel.
I used Tigaseal to bond my plastic arch trims to the body of my coupe. haven't fallen off yet!
Nige, that stuff looks good but the tubes don't look very big so may need quite a few.
I was thinking tiger seal as we have loads as work. That is an option.
I will be counter sinking rivets and using them aswell, the adhesive is to just to give it that extra something.
That stuff seems ideal. You ever used it?
Not yet, i have it to fit my front valance back on the Polo as i don't weld though ha
We sell it at work and the electricians who have used it think it great.
i used 'sticks like sh*t' on my plastic arches and you can basically lift the car up from them. aslong as you have some sort of prolonged and spread pressure over the whole contact points
Use baby glue.
Doesn't really cost anything, just a bit of effort, and babies don't fall apart do they? :)
In Australia we use Sikaflex 227 see www.sika.com
Use it to attach body kits etc.
Sikaflex® 227
Sikaflex-227 is a one-component poly­­urethane sealant designed for car body construction, curing on exposure to atmospheric moisture to form a durable elastomer.
Close Details
Use
Sikaflex-227 is suitable for sealing, seam sealing, simple bonding as well as for vibration reduction and sound deadening measures in crash body repair and car body construction.
Suitable substrate materials are metal primers and paint coatings (two-part systems), metals, painted plastics and plastics.
Characteristics and Advantages
OEM approved quality
Fast overpaintable
Resistant to ageing
Low odour
Can be sanded
Bonds well to a wide variety of substrates
Short cut-off string
Overhead work possible
Fast curing
Silicone free
Colour
Black & White
Packaging
150ml Black & White Tube
200ml Black & White sausage
310ml Black & White cartridge
Edited by Gigitt
I'm confused.
First you said you wanted something to stick plastic to metal. Now you're saying you want to stick plastic to paint..?
Two very different things, as you'll know if you work in a body shop! I was gonna suggest seam sealer, as you should have some around, its fairly flexible, the plastic should hold up - but paint will not.
Might help if you say what you are actually trying to do.
Doesn't really matter which way I said it, would of been the same result in the end.
Its all sorted now.
It was for when I was making my custom bumper. Grafted an 8v grill into a 16v bumper, hense, metal to plastic. Ended up using tetroseal sealer and counter sunk rivets to bond and fix it all together.
Some pics.
Bottom cut out and trimmed.
082839A5-2F09-44BA-AF54-28C5EB734A42-112
Trial fitted.
B68520B0-43DE-4AC6-893D-4E55708A8CFE-112
Bonded on and fixed with counter sunk rivets.
D1038633-EB0D-40EC-A35E-55C7DFFF680B-112
Removed and smoothed the recess, plastic welded up the tow eye and top vents and reshaped the whole bumper.
D4700BF7-112F-4548-9CFA-03DAC9777C8E-668
Looks good Rob :thumbsup:
