Key stiff in drivers lock
My key is quite stiff to turn in my drivers door lock, can anyone tell me is there an easy fix posted somewhere for this or is it a case of firing some oil into the key hole?
~Cheers in advance, Bill
  • Views 2.9k
Same problem but on both sides! Tried some WD40 in them but it just made the key go in and out easier not turn easier.. I think its a case of getting the door panel off and lubing the mechanism! Will do it when I can be arsed and let you know how i get on!
sounds like fun, cheers man
I had this on my passenger side, and had a different key on the drivers side... My solution was a little different though.. Instead of fixing the stiff lock and getting the lock on the drivers side back to the right key, I fitted remote central locking :L
dont know what car this is for but I had this problem with my 6n2 and fixed the lock with parts from vw for around a tenner for both locks
pretty sure theres a guide on here something
Don't use any sprays like WD40 in ANY locks... yes it might unstick them but it will now attract and trap dirt and junk inside the lock making it worse.
Best and Only thing to use inside a sticky lock is Graphite Powder. You buy them in little bottles and you basically slide the nozzle over to open and then squeeze the bottle to inject graphite powder particles into the lock. You can also put some on the key before sticking it in.
