9n only blows hot air....any advice
As above, when turned to fully cold the heater still pumps out hot air... its the manual knob in a 2003 1.4s, says climatic on it.
Anyone cured this problem.... cheers
  • Views 780
my 9n tdi does the same thing. apparently there is some sort of stepper motor which controls the heater flaps burried in the dash somewhere on the passenger side. haven't got round to fixing it though, as i cant be arsed to rip the dash out
http://www.tigerstyle.co.uk/phpBB3/viewtop...f=8&t=52145
Edited by g40jon
Check fuse # 29 in the main fusebox and the fuses on the battery, if you have access to vagcom you can test the temperature control motor
