Bubbles in lacquer
I had my saloon resprayed 5 or 6 years ago now (time flies!) And over the last couple of years lots of 'bumps' have started appearing in the lacquer. Particularly on the bonnet but recently they have started coming through on most large panels like the boot lid or roof.
If I had to guess I would say that it's rust rearing it's ugly head under the paint. Internet says it could have been caused by residual moisture on the panels before they were primed that has caused rust under the paint.
Anyone got any thoughts/advice on this?
Thanks!
  • Replies 18
  • Views 1.3k
Thanks!
happening to mine in places too, was it a garage job or correct spray booth with extractor fans ect ? mine was in a small garage by a friend, so would explain moisture ect like you say bro
Have you got a photo of the offending area Gaz? Surprised if its rust.
Edited by Vic
can be something as simple as to much solvent inbetween layers of paint which hasnt had enough flash off time. its really hard to say as some things take a while to rear there ugly head and in that time you can guess lots of reasons
Sounds like micro blistering to me. Which is effectively trapped moisture under the paint and/or lacquer.
They are caused when the water tries to evaporate and pushes the substrates upwards, causing "small bumps".
But that all depends on whether the bumps small.
as others have said trapped moisture is a likely cause, but also as kiz has said, trapped solvent can cause the same effect too (though this is normally due to being over eager to wax the fresh paint. the wax traps the solvent in and causes the micro blistering)
has it had a car cover on it at any time sinse the paint job?
Just what I was about 2 say
sounds like it to me
Edited by doyler
x2 it's like braille!
Mine was an incredibly cheap re-spray in '08 (basically sorted him out with a ton for a day's booth space), had i known how good it was gonna look in photos i would've paid more for a better job in the flesh :lol:
The prep wasn't too bad because it wasn't taking space and we just did a bit whenever time allowed, but this meant it was outside and the primer got damp - fail No1.
I think the main fail though was in throwing a thick coat of laquer over fresh paint. I think it was painted the day before and we threw one thick coat of laquer over it the next morning, which went more mottled than a hammerite'd jaffa, missed a few bits, got a few runs, some fish eyes, so sorted those like two hours later before it was even dry enough to sand, then pulling it out for lunch..
I wasn't expecting it to be an ultimate-dubs job, just the old paint had gone awol (surface rust everywhere, dead wing, entire square feet of laquer missing), so i'm not really bothered. But i definately have the same fine braille finish today, which i only noticed this autumn. Although for the last two years i haven't so much as washed it. as it's been parked up in a damp shady corner.
It's been garaged most of the time since the respray. I have had to evict it a couple of times to finish off a few other projects in the last couple of years but it's back under cover now. And it's probably only since I've been evicting it that the problem has appeared/got worse. I've never put a car cover on except a brief trial fit of the one I bought for the audi; it was too big and that was that.
Braille is a good analogy! I'll sort some pics next time I'm out there, probably this weekend. The bumps vary in size, some as small as a pinhead, some a couple of mm across.
The car was resprayed at a place with a spray booth, although it definitely wasn't an industrial grade one. I remember the garage as a whole being a bit on the damp side, especially where he stored the cars between jobs; it was inside, but his whole business was under a railway arch.
jsut the same as my golf... nice paint job but since being stored outside - its terrible.
Apparently it can be moisture in the air line as the paint is being shot.
Only cure apparentlys is sanding back and starting again.....
Some times that doesn't even work you have go back to.bare metal
You can flat back and polish it...for a temporary solution. But it 9 times in 10 comes back.
As Doyler said, bare metal is usually the option.
Edited by BigSexyRob
Pics aren't very good but you can see it's not a pretty sight!
You have got Micro blisters :( caused by damp in the air when it was painted. The only thing to do is have it repainted but if it's just sanded down and painted it will come back after a few years. The only way to get rid of it properly is to bare metal it.
Edited by bugpolo
Bad times! :cry:
Rat it!
I don't care, I've got filler falling out of mine and rust everywhere, it's maturing like a fine wine :lol:
Yeah there are other areas of the car I'm not happy with. The front arches were not done properly and underneath needs a bit of attention (usual place on the back of the o/s sill)
So I'm going to 'sod it' and just keep it going. It's 30 years old this year!
I had a similar case which was silicone contamination.
Looked lovely in the workshop, then after a few weeks the whole thing looked like it was going through puberty, only thing to do was get a gallon of nitromors and get it back to metal. Then start again.
Turned out that where the inlet for the booth came from, there was a car wash. And even though it had filters and heaters etc, it still got in and onto the paint.
I would recomend that if you have to wax a newly painted car, use stuff that's silicone free as it will no doubt harm the paint.
