6n2 Gti rear hub nut torque setting ?
Hi,
Ihave just changed the rear wheel bearing on my 6n2 gti and need to know what torque setting to tighten up is ?
cheers :-)
  • Views 6.2k
Wheel hub with wheel bearings
The wheel bearing and wheel hub are installed together in a housing.
This wheel bearing/hub unit is maintenance and adjustment free. Adjusting and servicing is not possible!
Self-locking 12-point nut, 175 Nm
◆ Renew each time after removing
Thanks Alot !
Ye i was quite suprised how easy it was to replace! :thumbsup: i just set the locking nut hand tight but at least can i get a torque wrench on now to be sure :)
