Name this part! (golf mk1)
Can someone name this part:
I need one and can't for the life of me remember what the bloody thing's called.
  • Replies 16
  • Views 1.2k
Goes by a few different names! Wheel bearing housing, hub assembly are the ones off the top of my head
That there is a hub.
you can get a free hub form BT internet lol
See here's the problem, that's what I've tried searching on ebay but still can't find the damn thing.
Hub. Knuckle, bit wheel bolts to, drive flange
Edited by harris.racing
its actually a hub carrier as the actual hub is the bit the wheel bolts to
Tbh I call them knuckles but that seems to confuse people.
Then again people say they're fitting coilovers when they have them from the factory.
Coil over damper.
What they mean is height adjustable
The ETKA description is either
wheel bearing housing or wheel bearing housing with calliper carrier depending on brake fitment and model :-)
But it does more than just hold a wheel bearing lol
OK interface unit between suspension shock unit & wishbone swivel joint & steering tie rods and brake caliper mounting point
Better, now go GSF and ask for tht haha
Sad thing is they would probably recognise that description and give you a blank look if you asked for it by the recognised names :lol:
There ate two different bottom ball joint sizes so be sure to buy the correct one
