Camera + 2 single din head-units
Hi All,
I'm wanting to fit 2 cameras to my car, for evidential purposes (you've probably seen the vids on youtube of russians crashing epically) one forward facing, and one rear facing.
I've already found the front facing camera i want to use and will find the rear-facing one myself.
My question is - I currently have a head unit with DAB which works perfectly for what i need but need a screen (or a cheap headunit with a screen) so that i can use the rear camera as a reversing camera too. The wiring won't really be a problem, just needs memory live, switched live and a ground which i can pick up from the existing head unit.
Can anyone recommend a screen / headunit with screen that i could use for this. only needs to be cheap as it's only use will be to show a live feed from the camera, it won't be playing DVD's or anything. It can't be one with a pop out screen as it would either cover my heating controls, or my main head unit. A stand alone screen would be perfect, but I can't seem to find the screen size it would need to be to fit into my single DIN tray.
All useful responses welcomed :D
All pointless answers / spam will be reported :)
Thanks in advance
  • Replies 20
  • Views 1.2k
You want a screen single din size?!
That's the jist of what I posted, yes
Good luck on that one!! Never seen that before.
I've seen them, just the screens tiny so good luck with the reverse camera..... Then again you could just turn your head or look in your mirror.
Thanks for the first useful response of the tread.
It'll also be used to quickly review the footage / initial setup, not just as a reverse camera
A rear-view mirror with built in screen might be a better option and have a bigger screen...?
How comes you don't want double din one mate?
Because I spent quite a bit on my existing head unit and wouldn't get enough from selling it to afford an all-in-one solution, so a bodge will have to do for now...
If that's the only feasible way then that's what i'll have to do, but I'd prefer to avoid it for now
Edited by Duey
Fair enough. This doesn't seem too bad
Boss Bv7320
The Ripspeed DVD ones had video in and two vid out ports and a 3.5" screen for viewing
What would you use as a recorder? as i dont know of any HU with record functions.
Could use a Go Pro? or buy one of those standalone crash evidence camera units.
The cameras I'm looking at have micro-SD card slots and record directly to that
Thy can show live feed through RCA and store to SD card
The front facing camera will likely be the v1000gs (some info if you google it)
Have you got any info / a link to the ripspeed one?
Do I also get an additional 5bhp for installing a ripspeed item? Lol
Boss Bv7320
Just had a look at this and it seems more than adequate, but it's a tad pricey. Like I say, it'll only ever be used as a screen so don't need usb or anything like that
This is on my 'maybe' list at the moment.
Hahaha, Ill go look now.
I ran a high power night vision camera mounted to a Ripspeed one i had and despite the screen size it was nicely viewable on camera and DVD.
here you go dude.
http://www.halfords.com/webapp/wcs/stores/...a=tsid:37143%22
It doesnt say the full list of connectors but on mine it was 2x tv out, 1x tv in.
Nice one thanks,
That doesn't look too bad either
To make the screen stay on, would I just ground the handbrake wire so it thinks the car always has handbrake on?
ye. or there is an option in the menu to switch off "park" mode. :lol:
There is also a reverse wire which turns the screen over to the camera automatically when its powered.
I have seen a rear view mirror screen before
It is literally the size and shape of a standard rear view mirror but its a screen for a rear camera for like vans etc basically I was going to run one myself but not van paneling my bready now
Il try get you a link later when I'm on a pc and I'm sure it was only around £50
I'm thinking of doing the same on my car when I have the spare cash
would it not be possible to get hold of one of the reversing camera monitors that they sell in the kits that fixes to the window.
how and where will you be mounting your cameras?
Oh! I've seen the single DIN head units with the tiny screen on! I thought u wanted a screen the same size as a single DIN slot - as in not head unit just screen! Just surf eBay you'll find loads in no time!
But obviously would be better off with double DIN. IF you do get a double DIN don't rest the screen on your gear stick when fitting like I did and now have no function of the fkin touch screen at all!!! :evil:
Edited by skamuk1
I could get a windscreen mounted screen but I want it to look discrete
If you have a look at the link I gave for the camera, it attaches just like a satnav - it has a sucker on it. I'll be fitting a sun strip after my mot which will hide it all and the lens will be just below the level of the strip so it would be difficult to see from the outside. As for the rear camera, I'm not too sure yet how I'd mount that.
