Treating Rust
I'm attacking the few areas of rust on the saloon today, but I'm unsure what order to do the various treatments in. None of the rust is really bad enough to cut out and re-weld. I'm thinking I will
- Wire brush the majority of it
- Kurust what's left
Now my conundrum, and I'm struggling to find information on this, do I skim with filler, directly onto the now-black Kurust or should I give it a thin coat of primer as a protective layer between the two then filler that? There shouldn't be much kurust on the bodywork as I'm pretty sure I can get the majority of the rust out of the pits, just the really deep bits
On a slightly different note, what primer should be used on filler? I've read that etch on filler can cause damage to the filler but you always have a bare metal edge around the filler so etch is needed here. What do people do?
Edited by prankstar2003
  • Views 931
id skip the kurust
clean it up the very best you with wire wheels /dremel , then bilt hamber deox gel
once its as clean as can be , joton jotamasic 2 part epoxy primer will give it good protection , its thick so will fill minor pits anyway ...if you need to fill , then fill over the joton
