boot spraying
hi guys,
I'm thinking of respraying my boot as one of the owners before did a really bad job of it :(
would i be able to get a good finish with just a aerosol can? I'm just worryed seeing as its a big surface and may come out patchy
cheers in advance
8-)
  • Replies 11
  • Views 1.2k
I don't rate aerosol cans personally. If you think that a large proportion of whats in them is just the propellant gas to spray the paint, it doesn't leave you with very much paint left to actually do a large job such as a full panel.
The result is you end up with a thin and patchy finish as you can't really do a decent thick coat, unless you buy 4/5 cans of the stuff!
The other downside is if you cant spray in an enclosed booth or garage, you'll likely end up with dirt/insects in the paint. These can be polished out later, but its more work you have to put in to get that decent finish.
I'm not saying it's not possible, just it requires a little more work.
i understand were your coming from tbh, the owner before did it with a rattle can but i dont think he/she even bothered priming it and it wasnt even laquered ... so you can imagine the finish its got.. its horrible :lol: yeah i was planning on doing loads of layers maybe 3 cans or more
If you use something like a red scotch pad and key everything up properly, then give it a wipe over in some form of degreaser that evaporates off quickly, you've won half the battle.
Most bits and pieces you can get off ebay or a bodyshop supplies place. If you do go to a bodyshop supplies place, you may be able to get them to mix you some 2k paint in aerosol form, but make sure the area your working in has good air extraction and you use a mask as theres some rather unpleasant stuff in 2k. It's why manufacturers have gone to water-based paints these days.
ok thanks mate :D ill start prepping it when i have time in the week :)
Here's what I was referring to.
Click!
Click!
It is possible to get a pretty good finish with normal aerosols outside. I sprayed this rear arch and lower quarter and sill outside, with normal rattle cans. I also did the arch and rear part of the sill on opposite side, and the drivers door bottom. Used less than 4 cans of top coat and 1 and a bit cans of primer for all of it. Couldnt see the blend either 8-) :
Rub down with 400 wet/dry especially if the finish is poor. Then 600 and maybe 800. If you're not down to bare metal, there's no need to prime. Wipe down with panel wipe (very volatile degreaser, don't use anything else that's not designed for the job, it will leave a residue). Use a tack cloth to remove dust just prior to top coating (and don't touch the panel with bare hands after degreasing).
Lay on several thin coats, starting spraying just off to one side of the panel and spraying to just off the other end. Move your hand down 3-4" depending on the shape of the spray then go back the other way, overlapping about half of the previous coat. Slowly (but not too slow!) work your way down the panel like this, leaving around 10 minutes between coats. No need to rub down between coats and make sure its about room temp if you can, difficult atm I know so may pay to warm the panel first. Do 3-4-5 coats making sure you have plenty of paint on there, and don't worry too much about the finish. Leave it to dry for at least 2-3 days as it is (somewhere warm if possible). No need to laquer if its not metallic.
When totally dry you can go to town on it with wet and dry. Depending on the smoothness of the paint, start at 600 (for a rough finish) working your way slowly, with plenty of water and a touch of fairy all the way to 1200, and beyond if you want (but you'll likely have a better finsh than the rest of the car by now). Cutting compound this and then polish and wax.
I know this is off topic, I'm getting parts of my car resprayed, As its 21 years old, Its lacquered abit, If i get the same colour paint as the car obviously will it still be the same, Because the guys debaged the boot lid and its got a diff shade behind where the badge was?
The paint will naturally change with time and degradation from age, light, temperature and so forth.
PoloD.
Edited by PoloD
Your a dick head, has to be said. :lol:
all the info i need cheers mate :D i think i may wait till the weather warms up to do it though and i may have to get another boot lid otherwise ill be without a car :lol:
