fuel cap stuck. help!
Hey! Need some advice on my mk2 breadvan, has a locking fuel cap that has stuck itself, the locking mechanism is normally a bit tight so I don't bother locking it, normally just twist and pull. But now its only twisting about a cmanand is sitting at the bottom of the cap so can't get my hand all around to evenly pull.
Stupid question but which was does it turn to come off?
Or any other ideas. Don't want to break the filler pipe.
partly solved it.
Broke it off.
New problem believe a piece of metal dropped in. Below is a picture of what I have left 2cysmti.jpg
Any ideas what I'm missing?
Ye, theres a small bit at the front,
Its not in your "anti-syphon" flap just inside the neck?
There wouldn't be an anti-symphony flap, surely? Mine hasn't got one and it's not a particularly old replacement tank.
Wouldn't worry about bits metal, I cleaned out an Escort tank once, keys/coins/lighter/bits of fuel cap, it had all sorts in it!
All 3 of my cars have had anti syphon flaps. Both the tanks i replaced and the new ones. Even the MK1. So I'd check in there. Have a look, but dont try and reach it with fingers if it is there, use a magnet taped to something, or something really sticky to get it out.
Thanks for the replys, I had to reach down filler next to get the spring out, that's when I heard the small bit.drop.
Then when I put petrol in it overflowed for a second straight away but now I think it's dropped as it took petrol at a steady pace after!
