FK Konisport 6n/6n2 coilovers damping adjustable
been on the car for about 9 months
no photos as they are on the car
•Superb height adjustable and damping adjustable suspension
•height adjustable from 20mm to 100mm on most kits.
•Konigsport use special Koni adjustable dampers allowing you to set the ride quality yourself.
•Shortened struts for increased damper travel and ride comfort.
£800 new
so £300 ono :D
Edited by damians1992
  • Replies 8
  • Views 452
Intrested mate how come you selling them ?
Ino you said no pics as on car when u taking em off to sell ?
Willing to split??
Are they on a 6N or 6N2? I'm sure the front springs are different on both.
I'm sure the springs do not matter, its just the top mounts are different, but apparently you can change them over from your original susp,. set up
I'm sure the springs are different. What car are they from?
Max
Max
If the spring is big at the top and small at the bottom, thats the 6n2 set up and the 6n top mount wont go on.. How ever if the spring is the same size like my ta's were the top mounts can be swapped between 6n and 6n2.
Here's what i mean
Will fit both 6n and 6n2
EA432606-DEC1-4F8B-BEDF-5B6149DA4EB6-392
Will only fit 6n2
AD6DD006-471A-46B5-9756-1E63D03E366A-392
Hope this helps
these still available dude??
Also do you know which car there off yet? 6n or 6n2"
