frozen out of 6n saloon
hi my car has no central locking. drivers lock is stuffed anyway but passenger door is frozen up. lock opens but that is it. no amount of yanking. on it will open it. is it a case of wam water down the sills? i finish at 3 and dont want to be stuck
  • Replies 21
Don't put warm water!! It will only freeze!!! Use wd40 or similar and soak the locks ect
Or worst comes to worst climb through boot
not got any. am at work. car outside in pitch black
its a saloon. pins for back seat are inside
Yeah, heating the seal up with warm (not hot) water is your best bet. When you've got in, dry the seal off or it'll freeze worse tomorrow.
Spray some silicon lube, or really cheap furniture polish, on the dry rubbers to prevent them freezing. Don't use anything with oil in on them.
Don't use wd on your locks if you can help it, it catches dust which will clog it further over time. If i've got an iced up lock I normally warm the key up with a fag lighter or some hot water (wipe it dry before you use it).
Maplin sell a graphite lock lube for a couple of quid. It's good stuff.
Yeh try and get by for now, all your locks need are regreasing, one theyve been stripped and regreased they wont freeze for a long time. Did it to my g. try some lithium grease for the rubber seals, it repels water and will stay on them
Vaseline for seals innit ;)
Piss on it
Piss on it
i would but cock shrivelled up in cold. got in. sprayed silicon spray all round seals. was fine then one door froze again. left them unlocked. will have half hour before i finish at 3 to get in again
I can't see why they're so bad
Lmao I'd rather piss on it and get home rather than standing next to it until summer
tbh, my boot was froze earlier, just ragged it open :lol:
Awaiting shrivelled cock update
My caddy was frozen up even after a kettle on the doors I just climbed in thru the back :)
Pre-icer. Works wonders if i'm parking somewhere on the street away from home for a while when it's cold. Cover it up at home though.
Yeah, I've had to put some effort in, that's what I expect in sub zero temps. Good strong handles, VW's have.
clean silicone lubed seals + clean door face = no problem
I have a saloon too and this happens to me! Use lock de-icer which lets me open the lock but then the whole seals freeze hahaha
Make sure the seals and the door are clean and dry before you silicon the seals. If it doesn't cover evenly, give it a wipe over with a clean duster to make sure the whole surface is coverred.
Mk2's do, I've ripped the lock surround trim off a facelift trying this though :lol:
Sounds a little gay but i use chapstick all on the door rubbers and if the door lock is iced up i heat up the car key with a lighter (just be careful not to melt the the fob ) :biggrin:
Once you got them open clean the seals and put a thin layer of Vaseline around them (as B-shaw said) they will never stick again
