Uprated engine mounts
Are there any Poly or uprated engine mounts available for the polo mk2/3 coupe?
  • Replies 11
  • Views 3.2k
Make your own. They're just blocks of rubber. Be careful though as you can just end up making the whole car vibrate.
I tried adding old poly bushes i had laying around and different spacers.
I settled on cutting a little off the steel tube so they compress the rubber more (may need shorter bolts I can't remember)
Phil J sells them
Look in the traders section.
One of the Golf Rallye G60 mounts is the same but uprated, were going for about £16 a couple of years ago, dunno the score with them today though.
They're available, have seen various efforts
solid gearbox mount ftl :lol:
1W diesel engine uses different rubbers to the other early Polos too, but they may well be softer to reduce the vibrations from the tractor engine.
You have pm mate.
FTW tbh Jon, stitch welding needed. the vibrations are cronic tbf
  • 10 years later...
Evening; Coupe GT 3F engine mounts. I've done the G60 conversion on the lower tunnel mount, but the other two need doing too. I can buy just the rubbers (867 199 383A) from Autodoc, but i've read they are a nightmare to install? There are many recommendations to buy the whole mount complete with metalwork, but this seems expensive and hard to locate, the rubbers are a tenner each.
What is a sensible, cost effective way forward?
swap em over , isnt that bad to do
