Stance Solutions Static + kit
I'm selling my Stance Solution Static + Kit that is new and unused, have to sell as the cash is needed for something else.
I'm looking for £300 for the kit as that is what I paid. I also have a new an unused Viair compressor that is needed for this to work, compressor will go £190 (I paid £200)
http://s916.beta.photobucket.com/user/juke...?sort=3&o=0
PM me or contact me 0seven81four484181 (Instagram @jt_dubs
Details below are taken from the stance solutions website to give an insight.
The system fits to your existing coilover set-up. When lift is needed the system is charged with air to raise the ride height by 50mm (or any height in between) allowing you to tackle any obstacle in your way such as speed bumps, multi-story car parks, tricky driveways, showground entrances...... etc
The basic kit contains:
2 x Static+ modules
5m of 6mm airline
all 6mm metal push connects needed
1 x schrader (car) valve to pressurise
1 x pressure release valve
1 x gauge to monitor system pressure.
Simply use a pump, compressor, air tank, with or without on board compressor, or a compressor plumbed straight in to charge the system.
the parts are CAD designed and analysed, precision CNC machined, hard anodised for corrosions resistance and PED compliant.
  • Views 370
PM'D
