More low... YES OR NO!
If your going the chopped spring route please consider holding off for new shocks or just coilovers. You'll encounter alot of issues with shocks and springs as the steering arm on the offside gets close to the brake servo amongst many other things.
I dont think cutting one coil will affect the car as much as this as it wont be mm of the floor like your or like others? so there wont be that much change from what it is now and as i can see there's no issues at all with how it sits right now so i intend on cutting 1 coil.. 1.5 at most! just to give it 10 mm so it aesthetically looks better!
if any of the problems mentioned were to happen they would be happening now not like I'm going another 40 -50 mm lower?
Sam
  • Replies 77
  • Views 4.6k
We can only offer advice, its your choice if you choose to take it.
i know and I'm very thankful!
i was just asking if my car is as it is now will 10mm make that much difference for the clearance and the other things mentioned?
Sam
