Removing/retrimming headliner and ABC Pillars
Looking a guide to removing the headliner and abc pillars in a 6n2 polo preferably 5 door
  • Views 1.2k
not so much a guide but you will need to
remove all four seat belts that are attached to the pillars, the pillars can then be gently persuaded from the clips i managed to break a clip off one of the a pillars so take care and be patient
then all sun visors, handles/sun glass holders, and interior light will need removing and also prise the top part of the door seals away in order to remove the headliner
it might also be worth replacing the rubber aerial seal while your at it if yours is worn
http://www.ebay.co.uk/itm/VW-Golf-Passat-P...=item5d29da65d2
