berg cup arches/ roll cages
finally going to get round to starting work on the polo mk1, thinking of a berg cup/ hill climb style build. may even attempt a couple of events myself!
so before i start trying to get all the bits together, I'm looking for some berg cup arches or similar arches, can anybody recommend suppliers? or recommend any other arches which people have fitted.
I'm also thinking about fitting a roll cage, does anyone know if a mk2 cage would fit? I've been looking online for a mk1 specific cage but i cant seem to find any, not too fussed if i have to get a cage custom made for it but would prefer an off the self unit.
  • Views 1.3k
Try the philJ section for the arches.
Highly doubt there is an off the shelf item for the mk1 as there would be no demand for it. You would be looking at custom as I'm suspect the shape/size of the mk1 is too different.
you would have to start with a mk2/3 cage and have it supplied without the flanges on the tubes for the front and rear sections so you can cut the tubes to length.
a few of us run safety devices cages
If you can't really modify a mk2 cage yourself it would be easier and cheaper to get a complete custom cage built
As buying a cage and then getting someone to modify it will cost alot more than going straight to a place that makes cages and getting a custom one from the go
Phil J definitely has a mk1 kit available, because he was telling me about trying to differentiate the mk1 he has lying about with the mk2 kit I collected from him :lol:
cheers for you help.
arch kit sorted and ill be getting a custom cage made.
