Misty Windows
Afternoon all,
Picked my 6n up few days back. Been raining quite a bit in my area and i've noticed all the windows keep building up moisture on the inside.
I've also noticed that my boot is pretty damp so i'm going to be replacing my rear light foams and possibly the boot seal as that looks pretty shagged too.
Is there any other obvious places to look that could be causing it to mist up??
Thanks :thumbsup:
  • Views 990
See if you can borrow a dehumidifier off someone and leave it running for a while in the car?
I've got a dehumidifier in my carfrom tesco, it was only 50p and it never gets any condensation at all now.
been told that a plastic cup with road salt in does the same thing, never tried it but its the same principle as the one I'm using now!
As mike said those Tesco dehumidifier pods are brilliant. and as i discovered today they fit under the speaker grills in the rear of the mk2F with a cable tie holding it in place so are hidden. :lol:
check the sunroof rear drains, they were clocged up to high hell in mine. is the front carpet/floorwell wet? does it even have a sunroof? i took the scuttle cover off mine (below windscreen) and there was a mess of leaves and gunk/water in there... wont help as there is a drain on the mk2's so I'm assuming there is on the 6n as i poked and poked with a screwdriver and ended up with a big black puddle and a dry under bonnet.
Thanks for the replies peeps, i'll give the dehumidifier a go and take it from there!
Cheers :D
