Hit a big puddle/pond :(
On my way home tonight in my 9n3 GTi, I went over a blind summit to find a large pond covering the road. I tried to brake in time but I must have hit the water at about 30mph :( (Bad driving on my part I know) Made it through just.
Anyway, carried on home, (about 5 mins) and it felt ok. Inspected the car when i got back to find my front number plate missing, but all trim was still in place.
Went back up the road to see if i could find it and noticed alot of flowing water from what sounds like the left hand underside, I wondered if anyone knew where it would be or hows best to get it out?
Also when i got back (didnt find the number plate) I listened to the fan(?) that runs after you turn the engine off and it sounded like it was gurgling water, I havnt paid particular attention to the noise it makes before but if anyone can shed some light on this that would be great.
Thanks.
  • Views 866
check all your fluids to make sure nothing is leaking if everything is fine it's just water draining from the cavities in the chassis/shell and nothing to be worried about, count your self lucky you haven't hydro locked it.
i would advise you to check for damage to your underside as anything could have been in the puddle and it might of caused damage.
i have no idea how the fan is making any sound like gurgling water so it might be the water draining or a coolant leak/ air in the cooling system.
Everything seemed ok on the way into work this morning, still need to check fluids though. Water sound from the left side has gone and the fan sounded ok.
I seem to have a lot of condensation build up inside the front headlights, do you think this will relieve itself?
WD40 is your best friend.
Spray all your connections and sensors in the bay.
Unsure on headlights, might need removing and drying.
Leave your lights on for an hour or 2 that should sort them
i hit a nice sized ocean the other morning on the way home. luckily it was more passenger side as my air feed wouldve gone awol but always a bloody good idea to drive through any unknown puddles slowly just incase.
had this years ago in my mk2 driving mashed through a flood. the amount of rocks and rubbish we hit hidden under water was stupid!
