2002 Bora PD130
Make: VW
Model: Bora
Colour: Reflex Silver
Year: 2002 (52)
Engine size: 1.9 TDI PD130
Fuel type: Diesel
Transmission: Manual 6 Speed
Mileage: 87k
MOT: 3 Jan 2014
Tax: 31 Dec 2013
Price: £3100 ono
No. Former Keepers: 3
Car is now garaged and will be until sold. You must have insurance arranged if you'd like to test drive the car.
Full VW service history until 60K, from then on almost every major part has been replaced/uprated and it has been regularly serviced by our mechanic who is more trustworthy than random garages and I get to be there while the work is carried out.
All of the invoices for parts are kept with him, if you'd like proof of any of the work I'm sure he'd be able to dig them out of the computer system if really needed.
Car has been well looked after, regularly washed and cleaned inside & out.
Just been serviced with new oil and filter, new ITG panel filter, Refurbed standard Garrett GT1749 Turbo, braided turbo oil feed, OEM 3 Bar MAP sensor,
NS inner CV gaitor and both drop links. Oil is always changed with proper PD oil.
Always used genuine parts from TPS through my friends account although some small things like
rear pads and droplinks have been aftermarket.
Standard Spec items:
- Rain Sensing Wipers
- Sport Dials
- Cruise Control
- Auto Diming Rear View Mirror
- 6 Disk In-dash Cd Changer
- Half DIS
- Net Optic Trim
Mods/uprated parts as follows:
Engine:
- Timing Belt and water pump done at 65K in 2009
- Reconned turbo fitted with braided oil feed fitted in December 2012 86K - 1 Year warranty on turbo(covered 300 gentle miles so turbo is just run in)
- Intake cleaned in degreaser bath at time of new turbo fitting
- 6 Speed Gearbox was rebuilt with fresh oil in 2009 as the casing cracked
- Flywheel and clutch were inspected and were given the ok. Does the standard flywheel chatter at idle when cold and has done since I've owned it from 30k, but I've done research in the past and people get this even when they fit new DM flywheels.
- Forge short shift
- Remapped to around 160BHP
- EGR Delete
- Brand new ITG Filter (December 2012)
- New 3 BAR MAP sensor(December 2012)
- Steel bottomed sump and pick up (Fitted in 2010)
- Standard exhaust but cat is removed
Chassis and Brakes:
- KW V2 Coilovers (2009, but top mounts have been replaced since then in 2011)
- R32 Subframe (Fitted in 2010)
- R32 Steering Rack (Fitted in 2010)
- R32 Lower arms (Fitted in 2010)
- R32 Hubs and tie rods (new wheel bearings at time of fitting in 2010)
- 4mo ARB and droplinks(new droplinks in december 2012)
- OEM R32 Bushes new when fitting the above parts in 2010
- Rear Axle bushes replaced with uprated Leon Cupra Bushes (Fitted in 2010)
- OEM 288 Discs and Ferodo DS2500 pads fitted in 2012 about 3K miles ago
- Rear Pads and rear wheel bearings were also replaced in 2012
Exterior:
- Has the odd scratch and little dings from car parks, but nothing too bad
- Had some fresh paint on the bumpers and sill to fix a dent(2013)
- Bora Sport rear Lights
- Standard front lights with grey painted inserts and 6K HIDS
- Mirrors and Grilles also painted grey to match BBS RS centres
- 4Mo front valance
- R32 Aero wipers
- Front bumper has number plate recess smoothed, I cable tie the plate to the lower grill for easy removal at shows
Interior:
- 3DR beige leather Recaro seats, they are heated but not connected, needs an additional loom. Condition Good, not excellent - no rips or tears.
- Standard VW mats front and rear(drivers worn at accelerator pedal)
but will come with new Justmatz plush mats that are brand new.
Wheels included:
17" Santa Monica alloys poorly sprayed white with low tread falken 912s - These were my winter wheels and will come on car.
Standard 16" Bora wheels with almost new mud & snow tyres (really noisy but fairly good tyres, even for normal driving) will come with the car too.
Price for everything as stated above is £3100ono
Additional wheels:
17x8.5 and 10.5 BBS RS's at an additional cost of £1700.
New car has filled the space on the driveway hence reason for sale. More pics will follow of current state late next weekend ( 1st weekend in Feb)
171754_10150089509565780_3678696_o_zpsb6
19079_104613632889767_4564574_n_zpsec331
179879_10150089512035780_3778140_n_zps54
29950_10150187777060514_6886984_n_zpsbad
You can look forward to this kind of MPG on long journeys, mixed journeys average 50mpg
417433_10151341477635514_1452606505_n_zp
19079_104613566223107_4394247_n_zps96f06
59400_155988617752268_3186618_n_zpsdfeb8
11868_178814545744_559356_n_zps9afc9699.
7527_101813386503125_1093262_n_zps692ce6
  • Views 540
Swaps for my golf gti
No swaps.
