Polo GT engine, bike carbs, manifold and set up
Carb set up with pedal block, throttle cable, filters, switch, fuel pump, lines and dizzy £350 p&p SOLD
zxr6 keihin bike carbs, long inlet manifold, facet fuel pump, y-piece, fuel lines, webber pedal block, one way vavle, throttle cable with 90 bend, vaccum line, switch for fuel pump (if needed) and filters.
polo gt engine
engine has had abit of work done to it and has done around 6,500 miles since the top end rebuild and shell change
ported and polished head (which has been done properly as you can see in the pics)
new VW Gt double valve springs,
new payen head gasket and full head set,
has been skimmed,
new gates timing belt,
new febi water pump,
new ngk plugs,
new dizzi cap and rotor
valves have been re-cut,
valve seats have been re-cut,
new front crank oil seal,
shell bearings have been changed
oil changed every 6k
new thermostat
i have all the receipts to prove the parts
engine will come with alternator,starter and gear box if needed
this engine is solid and is very quick for a 1.3, has been running bike carbs for the last 12k
Location is in Bangor N.Wales
Price £140
work done
Edited by wideboi
  • Replies 37
  • Views 2k
hey, is there a picture of the engine in the car at the moment ?
yeah man
awrite dude,
any chance youd willing to sell the gt box and starter on its own?
cheers
If u break interested in the alloy rocker cover
Whats needed to get it running on injection or are you selling with the carbs, also would you be willing to pallet it?
engine prov sold
awrite dude,
cheers
gt box has gone so just got the 5 speed out of the mh. and i can sell you the starter if you want?
i didnt buy the engine with the injection system and no it would be just the engine without carbs and inlet. to be honest id prefer collection
ok no worries
awrite dude,
cheers
awrite dude
what code is the 5speed from the mh? and is it a slim starter?
i have an afh with standard flywheel and no starter atm, if i get a slim starter then ill look for lake mk3 fly.
cheers
awrite dude,
cheers
awrite dude
cheers
awrite,
I'm not gonna mange these this month man. bank accounts saying no! haha
cheers tho
awrite dude,
cheers
awrite dude
cheers
awrite,
cheers tho
engine back up for sale due to time waster
does thi have the wiring loom
no it dosen't, nor a dizzi. this is just engine and box, alt and starter
still for sale mate?
yeah shes still for sale
bump
How much for the carbs and manifold?
Is that everything you need carb wise to run on another GT? If so PM me I could be interested :)
pm'd
will that headgasket work on a standard 1.3 engine from a mk2? would you sell it separately?
ahh sorry dude, the pic of all the gaskets and that is to show whats been put on the engine, not just cheap shite like :)
Would you be able to meet somewhere? Live in Newport South Wales, pretty hefty drive haha
